dual 5t
Roof have you thought about doing a Mid Motor Mod? not sure if you could pull it off, but a mid motor unit would be much better balanced and should be easier to control?
hmmm, funny you should say that
mantis LT mid eng, been on it for a month now, just working out the susp angles, gonna run 4 shox per side on the rear, the susp pivit point will be inline with the drive shaft coming out of the gearbox, abit like a motor bike swingarm and chaindrive down to the wheel, if i get it right you could swing the susp almost 180o with out the shox on, keep it under your mate:censored:
hi, its a full tube chassi, you use the rear lower engine plate from the baja but thats about all, the rest fits to the chassi including the front suspension
hi i think it will have its own front bumper welded or bolted,im on the front tonight sorting the shox tower/ front bumper section
Fook Den,thats ridiculously good again!!!! Jack the restaurant in and go for the fabrication! You will make a fortune with the skill you have.
Great work mucker!
J.
hi thanks guys, got a bit more done but a bit slow, must be getting old:helpsmilie:
doing a bit of selling the chassi but its had work
hi cheers, hope to get a bit more done tonight, got an appointment with the dunes on sat with the boys, trying to get my sandrail mkII done aswell, no time to sleep, got to save for my holiday in wales at woodlands, wonder if thats near voo, could knock him up a pint:clap::rockon:
