dual steering
firefighter9780
Just was wondering if all I needed to buy was the redcat dual servor kit and another servo or is there more to the mod that I'm not seeing
right, only thing I see is the holes drilled in the chassis for the radio box your chassis might or might not have rhem drilled already.
from what i ve seen the radio side servo is a bit offset to the other one. does this create any problems? isnt it critical to have the two servos aligned?
When iIdid mine I made sure the radio box was parallel to the siderail and try to match the radio box servo location up with the position as the other servo so they look even i messed up the first try and the radio box was too close to the motor and I couldnt, open the top,take your time and good luck :)
