Deluge1
That's too lean, dude. 25:1 is about 5 ounces of oil to one gallon of fuel. A Ratio Rite cup makes life easier.
Ratio Rite Oil Measuring Cup
Then it work for a half a gallon. Is it about a 2.5 oz bottle?bigboysrctoys said:Says for 50:1 mix 1 btle with 1 gallon of gas
That'll work.bigboysrctoys said:I did 5.2 oz to a gallon
4 hours of run time? Negative. Just do a few warm up laps and give it hell from there. I start tuning within the first tank or two.bigboysrctoys said:Got 2 put a tank through it tonite, little sluggish but figure thats from breakin settings, how long before I start tuning? The manual says about 4 hrs of run time before rings r seated.
Tune the HSN first, then the LSN. Check the plug color while you tune. To do this, do a high speed run and kill the engine immediately, don't let it idle. Pull the plug out and check the color. Dark and wet is rich, light and dry is lean. You want to hit it right in the middle, which is a brown paper bag color. Also, when you adjust the needles, only turn them a 16th of a turn at a time. A little goes a long way with these engines.bigboysrctoys said:Good! Didnt wanna wait for 4 hrs. Now low end is really slugish same w mid where should I start? No smoke coming out of it at all. Guess I should just read and search but I don't get a lot of time for that.
An 8k clutch spring will help that take off.bigboysrctoys said:ok thanks, thinking of doing a carb also any thoughts? i don't need a speed demon (yea right) but I don't care for the take off one bit
