Dune Runner no spark please help.
schris35
Junior Member
Gents,
I just picked up a used Dune Runner. All the electronics seem to work fine, I just can't get it to start. Pulled the spark plug and it's getting gas, but to spark.
Any idea where to look now?
Thanks ahead for you help.
Chris
In order
1- Replace spark plug.
2- If no luck, check the coil to flywheel gap.
3- If no luck, check shut off switch for possible shorts. Unplug completely.
4- If no luck, replace coil
5- If no luck, report back.
Good luck!
designed2survive said:
In order1- Replace spark plug.
Good luck!
That's pretty comprehensive D2S
