dunerunner 4x4 run time
auto2
what is your run time with the 4x4 dunerunner? i don't think im getting 10 minutes.
shoot i get 45 mins or more..never even checked because of a manual ShutDown
can you explain more of your issue?
after 10 minutes going arund a med size oval track the engine cuts out in the turn. tank almost empty. im thinking it was a combo of me not filling it al the way up cause it got an air pocket on the other side and fuel line not in the tank right.
if i tilt it at an angle the tank fills up all the way.
havnt tried it since with all the rain.
Rain where? it's been beautiful all weekend!
You should get 35-45 min on a full tank...
If the clunk isn't set right, you will see issues at 1/4 tank...I do...
Also, you may want to check your fuel cap...there's a little hole that needs to be clean...I believe it acts like a pressure vent.
also check to make sure the right line is hooked up.
I seen some come boxed with the vent line hooked instead of the clunk line hooked up.
the front line on the tank is going to the bottom of the carb.
what is the correct setting for the clunk? mine is lieing on the bottom of the tank with lots of hose so it flops around.
i had the stock engine but i put in an 27.2 race port and am breaking it in and it seems MUCH better. 4th heat cycle and max 1/2 throttle is about equal to the power of the stock engine.
