So this is my Dunerunner I have had for a couple months. It's been run hard and haven't broken anything even after several 10' high jumps and hard landings. I have a list of upgrades and parts I have added. The CPI pipe makes amazing power over stock and it's not crazy loud but it was designed for a MT and XB so I have had fitment issues. I rubbed up against my rear roll cage and melted part of it. I coated the area on the roll cage with JB weld to protect the roll cage from heat and it works. It doesn't look great but it keeps the pipe from melting through the roll cage. I also had to cut the wing on the ends for the pipe to fit without touching it. If I had to do it over again I'd probably still get this pipe as the power it makes is damn impressive.
I have left the gear cover off on purpose. I haven't had any issue running with it off. I cut the body down some. A hard landing broke part of it and the rear mounts were all ways a pain to remove so I just eliminated them as you can see in the pics. The only other thing I may do upgrade wise is swap out the engine but the stock one is fine for now.
Redcat Dunerunner Upgrades
- Walbro 990 Carb
- Z-RC TALL Blue Insulator (1" height)
- Snappy RC Ultimate Fuel Line Kit
- HPI Air Filter
- Team Chase Carb Diaphragm Filter
- Outerwears Pull Start Cover and Air Filter Cover
- 8,000 RPM High Performance Clutch
- Hitec HS-805BB Steering Servo
- Hitec HS-645MG Throttle Servo
- CPI Racing Tuned Pipe for Redcat Rampage MT/TT – Black
- NGK CR7HIX Iridium Spark Plug
- DDM "Black Magic" 6v Ni-MH 5000mAh Hump Receiver Battery Pack for HPI Baja 5B/5T
- Killer RC Super Bee Kill Switch
- Flysky FS-GT3B Digital 3 channel transmitter and Receiver
- Pro-line Desperado HPI Baja 5T Front/Rear wheels
- Hostile Crushers Tire Set for HPI Baja 5T (Soft Compound)
- 24mm Rampage to Baja Wheel Adapters
