Dunerunner questions
Rampagenewfie
Junior Member
Hey guys I'm looking at getting a dunerunner and was wondering what are the most common parts that I should stock for the driveline and suspension. Also wondering what is a good pipe to fit the dr with little modification. I would prefer a rear mount pipe
The rear dominator is the poop!!! The jet pro v3 would be a good pipe as well. Also got CPI as well... For sure need to stock up on dogbone pins.
I have broken many front a frame lower arms... 13 bucks for a pair, the good news is they are ambidextrious (spelling?)
That is the only part I have actually broken besides the flimsy body. Other than that just the normal upgrades... killer bee and better air filter :D
Add a piece of fuel line in the drive cups to keep the dogbone centered and that will help prolong their life as well.
I did that and they still mushrooming my cups. I think it is time to invest in axle boots and that's a lot of boots!!! They are on ddms black Friday list so we will see. I don't know anything about toobz. Does anyone know if they will fit or am I better off getting steel pipe and welding or some other way as I don't have a welder
The Toobz won't fit. Steel tube works fine. It fits tight you can red Loctite or a bit of epoxy will hold them on.
Does anyone know of the size of tubing I would need and if my local hardware store would have the size or is there something I could order online. I don't want to use carbon fiber or copper tubing. Thanks.....
