So I guess, if any of you think you have a CY in your Firehammer, check the number of bolts. I feel dirty and violated now. Is there a smiley with a guy bent over a chair?
Good one !!! We could actually use one of those. Yea it's crazy, but to be honest all I ever was around were the Smartech brand. Coming with a CY engine, that was awesome for adding your choice big bore kit. I had no idea they moved these junkers over to the 2wd's. The one I showed was from a 4x4 titan. I was not around the Duratrax / Carson / XTM models. Best options for that engine are :
Junk the can muffler & stock carb & airfilter.
Add a pipe
A 603 carb
Better air filter HPI/k&n
You'll get the maximum that it's capable of that way & believe me it's way better than stock.
I have a 26cc CY takeout from a 5bSS kit for sale too if your interested PM me.
Once you get the CY bottom end, as long as your coil & mounts & fan cover will work, your golden. From there, you can build anything you want.
Sorry to have brought such bad news upon you csp. I was just trying to make sure I know what I have when it gets here so I can map out an accurate modification/upgrade plan.
This is another one of those threads you sort of wish you had not read.
Some good info to know. I had to run down in the RC room and count the bolts and low and behold I have a running paper weight when it comes to mods besides the pipe and carb and filter. Pretty dissapointing here because I was looking to see what I can do to it in the future also. I feel ya csp.
Them damn slanted eyed hobbits always getting over on us here.
It sucks, but the engine has worked pretty good for me. So don't be too down. Get a tuned pipe and you won't even care. I've run mine for almost 2 years without any serious issues! :chinese:
