just tell her you THINK your gettings symptoms of Parkinsens Desease. Not to make lite of the desease, as its perticularly evil, but it would explain a whole LOT Of new stuff arriving at the door.
i would say limited.
you must use digital servos. its set to 5.5ms timing (communications with the Rx) and anything under 18ms can/will fry analog servos.
its also somewhat limited on setup and adjustments.
lastly i know ALOT of folks (i was included) that had glitching issues with Spekys on Gassers, and lastly, if you want to use a remote kill switch, you have to get one designed to work with the Speky.
for a similar cost, you can get an Airtronics, FXHS3 2.4 system. or bettery yet and a bit more ( 180ish usd) you can get the Futaba 3PKS 2.4 or 3PMS 2.4.
