MTXL Dynamite kill switch
Ethan_Dorsett
New Member
I have a mtxl paired to a fly sky FS-GT3b transmitter and I wired up my kill switch. When the kill switch is plugged in and red light is lit engine doesn’t fire with the light on or off. But when I unplug the kill switch from the ignition it fires right up. When I plug it back it the engine dies. I got a OBR 34cc engine. How do I set up the switch to the transmitter? When I press channel 3 button the light turns off and on just fine. I don’t know what issue I am running into. Any help would be appreciated.
Did you make sure the killswitch plug is in the right way in the receiver? Technically if you reverse the plug you will put the signal wire on the ground pin. Just a thought.
