Dynamite killswitch override
smurfer69
Weston super mare
hi guys
has anyone having dynamite killswitch installed
turn on car light is off
turn on transmitter light goes on
all is good
what if , turn on car light off
then forget to turn on transmitter
but car still starts for about 10 sec then dies
now in-between that 10 sec turn off transmitter
engine starts to excellerate, and only way stop
it is turn low needle down till engine get starved
which is almost instant
Q have I just overrid killswitch by forcing engine to start
is that even possible ?
it was working before that
I can start engine fine no issues but killswitch won't kill
well before anyone does reply
found wire had vibrated itself loose from
killswitch on engine, just crimped it tighter,
might go back and solder the bar steward on
later tonight ,can't have that happen on beach,
well anywhere,
maybe this will someone else out
hi guys
all is good
Are you using the proper spark plug? Cuz sometimes it you use a non resistor plug it will accelerate with you controlling it. That had happened to me once, make sure the spark plug is a RESISTOR type
appreciate reply cheers, yeah I am , its all good now wire had
come loose from vibration, crimped it tighter,
gonna try n start im sure it will work , easy fix from stupid mistake
Lol we all make those kind of mistakes! Personally I'd solder it to be extra sure. Oh speaking of which did you try the exhaust?
yeah im gonna solder it can't take the risk on a runaway,
when I tried making vid of running f--king thing wouldn't start
just being a pain , I did get it going and its holding,
honestly I think its time for strip down and rebuild, or sell
wow what a hard question never really thought of it, there
is so much more than just the car, only things I haven't upgraded
is chassis, fuel tank battery box,
everyone knows what they put into there projects, literally
hundreds of hours , and £$ thousands
My truck is pretty much stock except for a couple things
its endless you just about any upgrade,
ive even got rear sway bar fittings because
plastic stripped out alloy much better,
but another expense, proberly just spent another
£100 rebuilding IRC shocks , its just endless
