Dynamite large kill switch programming
Cheifbobo
New Member
I have a losi 5t 2.0, and need to set up my large scale kill switch to my dx5 pro. Does anyone know how and could explain how to program the switch to a button? And on the same channel? Thank you so much
That manual doesn't help with what he's asking @moliver
So what you do is go into your tx settings and find auxiliary and find what button you want to use. You can set it to momentary or an on/off button. That being said you must first select your aux output 1 thru 3 on the transmitter first then re bind your tx/rx while holding the button you chose to activate the killswitch. Then you should be good to go
