new-fg-owner
hey guys
got the ecu soldered on perfectly nice working awesom changed the maps ect, i soldered it onto the igniton coil connectors from the superbee grey cable! but didnt connect it upto the receiver or the actual superbee itself.
so the ecu and engine run beautifully i was super pleased. yesterday i connected everything together so connected the superbee to the grey wire to the igniton lead. fired up the engine, the engine revved very very high for about a second ECU came on but then both went off!!!
since then the ECU has not worked at all whenever its connected to the engine it will not work at all, but as soon as i unconnect it the engine fires up fine. i know its not the wiring because i've checked double checked and checked again.
update on whats happend, i've tried everything a new killswitch just the button switch igniton coil, tried soldering black to red n red to black and red to red and black to black!!
both times the engine started without the ecu connected but as soon as i connected the ecu to the ecu wire the engine just would not start nothing happens at all.
the ecu worked utterly perfect instantly as i said before i connected it to the superbee now its just as dead as a do do i don't understand whats happening
tried it on both my cars to with a new ignition coil, new spark plug everything and still nothing.
