Found this bit of info on another forum, thought it might help out to have it here.
ADJUSTING FRONT AND REAR GEAR DIFFERENTIALS
Gear differential action is adjusted by filling the gear differential with differential oil of a specific viscosity.
Differential oil is rated with a “viscosity” number that indicates the thickness of the oil, which determines how much the oil resists flowing. Differential oil with a higher viscosity (for example, 100,000 oil) is thicker than differential oil with a lower viscosity (for example, 40,000 oil).
• To make a gear differential LIGHTER, fill it with thinner oil.
• To make a gear differential HEAVIER, fill it with thicker oil.
EFFECTS OF FRONT GEAR DIFFERENTIAL ADJUSTMENT
Lighter Front Differential (thinner oil)
• Decreases understeer
• Decreases stability under braking and acceleration
• Increases chance of traction roll
Heavier Front Differential(thicker oil)
• Increases understeer
• Increases stability under braking and acceleration
• Reduces chance of traction roll
EFFECTS OF REAR GEAR DIFFERENTIAL ADJUSTMENTLighter Rear Differential (thinner oil)
• Decreases on-throttle steering
• Less acceleration if the grip is there
• Less predictable car (cars with very “loose” diffs have a tendency to understeer heavily under throttle and turn-in oversteer as soon as you lift)
• Less on-throttle oversteer (snap-oversteer)
• Less turn-in understeer
• Less stable under braking
Heavier Rear Differential (thicker oil)
• Increases on-throttle steering
• Better acceleration if the grip is there
• More predictable car (cars with very “loose” diffs have a tendency to understeer heavily under throttle and turn-in oversteer as soon as you lift)
• More on-throttle oversteer (snap-oversteer)
• More turn-in understeer
• More stable under braking
