I bought a used 5ive B that's already setup as electric and it uses the engine to brake, as expected. I'm wondering if using a mechanical brake, with a brake throttle will help save the battery and prolong motor life?
it just seems like a lot stress is put on the motor to stop all that momentum and weight from speed. Im also used to gas power so i'm a
little more used to mechanical brakes and the adjustability than an electric braking which just bites.
Thoughts?
Thoughts?
