sunoco
- Reaction score
- 29
had the car on the stand running this evening. was slowly leaning out the high speed fuel screw. held the throttle wide open- pushed the 3rd channel- no ignition shut down. always worked at idle- mid throttle- no issues @all. - first thing that came to mind- bad kill switch- or wiring.- switch is a killer bee.- so back to the bench the car went. turns out to not be the kill switch at all.-- some time ago, i installed a direct servo harness.-- what this does - it bypasses the hot- positive wires on the servos from going tru the reciever.- good idea really- seemed to feed slighty more juce to the servos- but-- it caused the kill switch to not operate when the throttle waswide open- work correctly at idle- mid rpm. The offending direct servo harness is setting in a box with all the other electrical stuff. It could be a good idea to test your kill switches, no matter what brand they are when the cars are running wide open- on a stand worked for me-- anything that can go wrong with rc- will eventually- just saying-----
