Engine and Electronics?
Clubin
Build Thread Contributor
Manitoba
Just to pass the time, I am curious to see what you are planning to install in your roller.
ENGINE:
I am installing a O'Neill Brother'srace ported and mahined 27.2cc. Brand new never ran.
ELECTRONICS:
steering servo hs5745
t/b hs5645
What are you putting in?
here's a useful bit of info I discovered yesterday, after rebuilding my ONB reed motor out of my FG I went to instal it in the TT and 2 things didn't fit, clutch housing...so had to pull it off motor that came with tt and flywheel cover! the mount holes didn't line up with the chassis which I found odd...so I don't know if these parts are redcat only or if the others were fg only....just something to watch out for.
I don't have a roller coming cos I spent all my money on the tt, maybe in the next batch.
If you put a Zenoah fan cover in the Redcat you have to redrill the forward hole in the chassis, it turns out to be an oblong hole. The cy and Zen clutch housings are different as well as you have described.
i have no idea!! don't have a motor, and the extra servos are probly not safe to run as i have had problems with them latly.. so far the only thing i have is a reciever:D.. so thats it.. im puting a reciever in it and thats all:mad:
Only a reciever? You'll have to make all the other noises yourself and pull it around.. lol
Agreed, about the cy engine, I did not know that either. Just a small major little issue.
I"ve got a 28.5 cy, digi4 or 5745, 645 or jr z9100t and not enough money left for a roller. My tt has lots of presents coming though.
I'll have to put all my bits on a skateboard for now, i wont have to make the engine noises like kryp but I'll still have to pull it:D
I have a extra spectrum RX I will bind .....I have 3-645 aand 3-805BB... one of those should work for what we need
I put the stock T-bolt motor back in and pulled the 26 cc marine head kit/ DS cooling head I'm slaping that in the buggy
That'll be cool to see.
oneills brothers 28.5 race ported engine..5745 steering.... 645mg throttle ....hitec servos......spectrum dx3r radio
