decky
- in my rc shed
i have a stock 26cc two bolt engine,i want to use the crank out of a 4bolt G270 racing engine as it is lighter and balanced so should spool up quicker,is this possible?
sorry you must have misunderstood the post,there is nothing of CY been used here,the crank is out of a ZENOAH G270 motor which is 4 bolt, how i know this crank is modified is because it is cut down lighter (when you look at them side by side) the standard one is much bigger,also before i bought this bottom end i sort of was told about it.
so i want to use A MODIFIED crank out of a zenoah G-270 **4bolt** and put it in ZENOAH 260 **two bolts** standard engine,is this possible
Please read Sharkey post and this is where the stuffed crank came into the conversation.
