hi again guys i drove the baja after i passed a pin through the gas cap and blew some air into it seemed like it was slightly open now so i ran it. but again the engine ran for about 5 mts and then stopped. i tried to start it but wouldn't start so i put all the settings to zero that means put everything off then tried to pull start it with the choke on it started and cut off as usual, then iput the lsn to 1 and 1/4 and started it did start but the rpm was very hi so i increased the needle setting to 1 and 3/4 then the rpm came down a bit ran it with the hsn at 1 and 1/2 ran a bit and then died again, but in the mean time when i accelerated and braked as soon as i left the breaks the rpm jumped up every time. i have done up the carb once as it was very dusty in the beginning where i used to drive so could it be that i have put something in the carb wrongly or some thing this is a real prob, and need help i have had to start the engine bu the method i described earlier with zero settings overtime or it would not start. any ideas some expert advice needed. thanx.
