I'm having some issues with my trucks idle. It seems that it idles really high after I let go of the throttle after a big acceleration, enough to keep the truck moving on its own for 10+ feet, then it will drop down to normal idle. Even at a stand still the RPM's will vary from low to high,then back to normal. I somtimes will have to hold the brake to keep it in place. I've adjusted the low speed needle, but the RPM's are all over the place. I was planning on spraying carb cleaner on it today to clean off the vents/breathers, has anyone had any issues with that? Thoughts?
