thesharkfactor
- scotland
hi guys,
big post..sorry!..
im just after fitting new front cable brakes to my marder/beetle. i bought a new servo for the job, hi-tec hs645-mg which runs the throttle, front cables and rear diff brake.
i set it all up, and all was well.
i took the car for a run yesterday and it ran fine for about 10 mins..first, i thought i was getting interference a couple of times as the throttle did not respond to commands for a second on two occasions....
aside this, all was fine and it ran for around 10 mins more as a mate was blasting around the tarmac with it, shredding my new tyres for me for, donuts and the like.
he ran off the tarmac on to the grass, and the car ran away...out of control..
i quickly took the radio from him and switched it off.... so the failsafe kicks in and applies the brakes. the car comes to a stop, grounded on top of a mole hill, the engine still running, brakes fully applied..(thanks to the failsafe!), but the wheels are still going.
i approached the car and turned the radio back on, the brakes release and the engine revving around 1/3 throttle, the wheels are spinning pretty fast. i cannot brake/stop them...no rear brake power.
i shut the engine down and take the lid off. i notice the throttle/brake servo arm has snapped clean off, on the rear brake side. the other side that controls throttle and front brakes is intact.
me, thinking i can still drive the car with the front brakes and throttle..i starts the engine, and it's revving high on idle..around 1/3 throttle, and, the servo no longer reponds.
ok..shut down..back home.
i removed the new servo and took it back to the LHS where it was purchased the day before, the guy stripped it down to find the motor in the servo had burnt out. luckily, he had a brand new servo, same model which had a stripped gear, so he switched the motors for me..and the servo was wroking again..i was happy, considering he told me they have no warranty.(?).
anyways, i installs my new servo, replaces the snapped servo arm and heads out again.
upon start up, the engine is revving high, around 1/3 throttle. the carb/throttle is closed...i make sure by releasing the throttle rod collet and going throught he normal routine of adjustments of the rods and servo arm....still, no difference..
still idling at a third throttle. i have tried adjusting the idle screw, no difference. i can slow the engine by closing the choke, but then when i try and accelerate, the engine cuts out.
i did recently install a samba pipe, but run a couple of times with no probs..so i guess it;s not the mixture that's at fault, but i reset the LSN back to factory (1 and 1/4 turns out) and i still have over revving problem..
can anybody help??
background info if it helps..
29cc CY engine, samba pipe, k&n filter.
i guess the servo arm snapped because of the force created when the engine was running fast and the brakes were fully applied..which caused the run away. so the over revving problem occured unnoticed just seconds before the run away (described above)
any ideas whats wrong with my engine?
big post..sorry!..
can anybody help??
