Engine life
ika
Hi,
How long stock Rampage MT 30cc engine will last without rebuilding?
Have I to replace stock bearings and seals I have not started yet, just new.
with GOOD air filter, consistent tune and fuel mix and reasonable load many years 500+hours easy.
somewhere around 300 + hours my 30.5 compression fell off on mine. but i ;ll blame it on stress and ultra fine dust. definitely within normal limits of my expectations.
remember they are on the ground eating loads of dirt eventually will get them. run it without filter or crapy filter ...it won't be long before its over.
if the bottom end is blown out, clutch maybe overheating and scorching the crank.
over something is out of round. it should have vibration but not "shaking the whole unit".
mud adds tons to the drive line and will kill most anything if you slam on it continuously.
clutch will go first if all holds together.
is ur unit eating alot of clutches?
phreerider said:
if the bottom end is blown out, clutch maybe overheating and scorching the crank. over something is out of round. it should have vibration but not "shaking the whole unit".
My MT is brand new, i have not started yet,waiting for some parts. So my question is: does stock engine bearings and seals work well and don't cause engine demage or its better to replace bearings and seals.
if the unit is fresh... run it! bearings are fine. case bearing are solid . no worrries get a carb /pipe and rip!
gear plate needs to be alloy! MT comes with that .
I got 668 carb and cpi pipe, replaced all bearing (except engine) and 8k clush installed. Waiting some parts ...
