engine parts
FH MT
Regina SK
what brand is the stock Fire Hammer MT because i what to get parts for my stock motor and i doesn't show the motor on any sites
thanks
There are two possible engines you could have on your Firehammer MT.
I have a 3 bolt one. It is probably about 90% not compatible with anything CY or Zenoah related. (If you have a 2 bolt head, it may be a Chung Yang (I think it says on the side of the cylinder)
1) The clutch itself is not interchangeable (see my posting on the differences: https://www.largescaleforums.com/showpost.php?p=46127&postcount=11) :(
2) The Carb is interchangeable! :)
3) The clutch housing on the CY's are not one piece. They are on the one I have, basically one with the crankcase. :(
4) Spark Plug is interchangeable! :)
5) No big bore kit for CY/Zen will work on a 3 bolt. :(
6) Flywheel is not interchangeable. :(
7) Fan cover is not interchangeable. :(
8) Ignition coil is interchangeable. :)
9) Pull starter cover is not interchangeable, but if you keep the guts together, they will work on a CY! :) :(
10) Crankcase not interchangeable. :(
Find out which one you have an let me know. I'm curious.
Let me know if you have any other questions on it too.
The Outerwear's pull start cover should fit. Not sure what would fit the rear of the MT. Any filter will work its a fitting issue with the small area in the rear.
