Just before I tear this 5T apart, again. I am praying to the LSF gods to send me a sign that I am headed in the right direction. After very first break in the engine flooded and I fouled a plug. I then changed the plug and got it up and running. Since then I added a Bartolone silenced pipe and turtle billet box with an offset filter. It was running fine. I had a rollover, but it still was up and running. I was tuning the carb on the low needle with a single 1/16th turn and after running it came back to me and died. I figured I flooded it so tried to clear the flood. No dice. I then took it home and changed the plug after an overnight rest. No dice. I then took out the spark tester… no spark. So now I am left wondering if I need to take the engine off to get to the flywheel/magneto/ignition coil. It has to be something there right? I know I set the coil off the flywheel correct. I even used a DDM spacer. Besides the it was running.
So my question to you LSF gods… is there anything else before I tear this engine off?
At this point I want to tear it off and throw it as far as I can. This 5T is making me about as frustrated as cat trying to bury his poop on a frozen lake.
