Hi, I have a problem with the engine g260.I changed all the gaskets.The first problem was a oil leak in the cylinder Gasket.I solved it with Loctite quick Gasket .while I had the oil leak in the cylinder gasket ,engine is working normally.After i solved that problem, engine is not working well.When i start the engine,he goes into high RPM.I cant reduced by adjusting the carburetor.So something is wrong.I put new gaskets and manifold.everything is tightened properly.so I do not understand where is the air leak.
Thanks!
Thanks!
