In advance, I apologize if this has already been discussed, I could not find an answer when I searched.
I finally got my XTs fuel line straightened out. Radio in, new 7.2v battery, needles reset and new carb/manifold gasket.
Started it with 1 pull, HS needle is set pretty good, revs up good and is fast! I think I had the LS needle set, but at idle, the engine kind of pulses or surges, meaning The rpms go up and down. Adjusting the idle does nothing. If I richen the LS up, it bogs and wants to die, leaning it out and the engine revs real high. I got it to to a point where it takes off great and winds out awesome. Just this little problem.
It was suggested that it could be an air leak, which I was told how to check. Is there possible anything else that I am missing?
Thank you.
Thank you.
