engine question
HI Juelin, bonjour mon ami. Have you switched your two gears on your transmission? Take the big gear and switch it with the 25 tooth gear right next to it. Just switch those two gears only and you will get a little more top end.Hope this helps.
If you want a good strong running engine go with a 34mm head and the 1mm stroker crank and that will give you good rpm and good torque
