Engine rampage xt
It is a HY (hung yang) which is a copy of a CY (Chung yang) any of the carbs that fit a CY or Zenoah will fit.
I also need a good airfilter.if I use the hpi airfilter with a outerwear prefilter do I have to oil the filter because I tend to use to much oil and then the engine bogs.
What is the best carb and airfilter to get for a stock motor from a rampage xt.The only thing i ordered is a ddm dominator but that is on back order so i want to try to get the carb and airfilter before the pipe so when the pipe is here i can tune it so it runs great.
The walbro 668 or 990 are both good carbs. The Baja filter is what most guys prefer if you like the dirt. There are a couple of other foam filters that work as well. The k&n filter style look cool but are only good on the pavement.
I have read that the walbro 990 is for tuned engines.i want i new carb because the stock carb tunes not well.when i turn the lsn the hsn needs udjustment to and i cant get a good tune
The 990 will be fine. It doesn't have a choke, so starting is a little different. It's easy to over oil air filters. What I do is, put the filter in a zip lock bag with some filter oil and massage it until the filter is fully coated. Then, pull the filter out and wrap it in some paper towels and squeeze out the excess oil. You want to keep squeezing until there's very little air filter oil being left on the paper towels. With this method, the filter gets completely coated without restricting flow.
I think im going for the walbro 990 but with no choke does it start good?here in the netherlands the temp is not high.between 15 and 30 *celcius
It requires an extra pull or so but if it's tuned good it starts good. Cooler temps you will want to run it a bit more rich. Some do prefer the 668 for the choke. Both are great carbs.
so this filter with the shreadstack?the inclined shreadstack one what out of stock so I will order the open angled shreadstack
/monthly_2012_03/media.jpeg.e1174cf195376927cfef356c2611c34b.jpeg
yes but on the ddm site it was out of stock but there is an open angled plenum shreadstack.can I use that to for the setup with the walbro 990 and the hpi air filter?
Yes I run those. No power gain, but the stock plastic intake can crack over time causing an air leak.
