Engine removal losi 5t 2.0.
Probably not...
Gas tank doesn't have to come off in order to remove the engine on the the first 2 versions.
4 screws on the bottom and throttle linkage are all that have to be removed in order to take the engine out....
Maybe a screw or 2 for the exhaust depending on what pipe you have and how its mounted.
CORRECTION!!!!
4 screws on the bottom and 1 screw on top + the throttle linkage.
I forgot that the 2.0 comes with that brace between the motor and center diff..:banghead:
Some other things you may want to pick up that will make it easier to take apart.
For the fuel lines.
http://www.davesmotors.com/KillerRC-Fuel-Tubing-Disconnect-Kit-KRC-AC-FTDK.html
or these are the ones I'm using right now...
http://www.davesmotors.com/DarkSoul-Fuel-Quick-Connectors-DSR0064.html
for the throttle linkage.
http://www.davesmotors.com/DDMRacingProThrottleLinkageforLosi5ive.html
