Engine screens
alfred e numan
Here are 2 photos for the new folks to look at. This will help keep the junk out of the flywheel-coil area. This is plastic window screen- Automotive Goop. I have used the plastic window screen on another eingine for about 1year, still looks good. -
on the pull strat i put the screen on the inside. looks alittle better i think. it's alittle tougher to do but works great.
I was wondering, what carb comes on the f270? wt-668?
Thanks for the tip
f 270
I looked at the carb, its a wt 668. The screen on the outside may not look as good, i am into function not form.lol! When i blow off the dried grass, seeds, all sorts of flotsom -jetsom with the compressor, the screen is less likley to disloge on the outside. The carb on the engine is a 990. i should put the unused 668 on the thumper weed wacker -- just for giggles!!lol!
I run a dirt track ,is there anything you can use to cut down the dust & dirt from getting in ,it's killing my pull start , I have to pull it off every run or two and blow it out and dry lube it .thanks Roger
This: http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.4500/.f
Quite expensive, but work great. I had one on my old baja 5b and had no problems with the pullstart.
And thanks alfred for confirming that for me.
I picked up the Outerwears for my Pullstart and air filter....best 49.00 i ever spent. Would buy again without hesitation
