Engine stand
Do you have anything covering the clutch ?
If not you will need to come up with something to do that.
If not when any higher RPM is achieved and the clutch shoes come out, they will nearly immediately make contact with the clutch housing, causing devistating damege to your clutch, the housing, and possibly yourself.
Here is a very good example of an engine test stand.
I did take this from another site Heli freaks.
Then your stand is only to start an engine ... Correct ?
If not, and you plan on tuning at all, or attempting to check performance.
You will definitely need a source of drag, or load, for the engine.
Personally I would want a test stand to be as useful as possible, but maybe you are looking for something different.
Yes im new to this all my thinkin was to srt it u r correct down the road i want to be more precise as urs but in just goin in baby steps lol but your advice is very welcomed thank u
Check out simple dyno works pretty well with an arduino. here is one i made that was gear reduced. now im working on making one that is a 1:1. surprisingly it was fairly consistent with its readings.
[ame="https://www.youtube.com/watch?v=E-tBEiIT5cs"]https://www.youtube.com/watch?v=E-tBEiIT5cs[/ame]
