Engine Swap Question
chazman1117 said:
Could someone help a NooB out and post the steps required to remove the engine from a Dunerunner?
you have 3 bolt on the side where the clutch bell is...and 2 under the truck..take off the roll cage and disconect the gaz hose from the carb....(((remember where goes the 2 carb hose!!!0)))and disconect the trottle lincage and there you go !!! :D
