I was driving my tt yesterday and it was awesome. Then I tool the carburetor and air filter off to clean in after I saw picture of dirty carburetor. Lucky on mine I had a little dirt. I cleaned it and putted everything back together.
Today I started the engine and started to have fun again, but then engine just stopped. I started again it was on for 2-3 seconds and died again. Then I started again and it died after one second. After that it won't start.
I took carburetor to see if there is problem. Then I checked pipe, which had loose screw... Also my pull start didn't go back inside, so I took it apart (side only) and fixed as I would usually do. Putted all back together and nothing.
So here me, on rampage forums.
Any first suggestions what to check?
What I checked so far:
- Check if there is spark: Yes there is
- Check if pull start is actually working: Yes it does, otherwise there wouldn't be spark
- Put the red thing in vertical position and then back to horizontal when needed: Tried, engine is almost starting but not really.
Maybe there is problem in fuel line but where exactly?
Thanks
Thanks
