loud72
I am at my wit's end. I took my DR out last Saturday and tried to tune in High jet on Walbro 813. When I'd start going up near WOT the engine just shut off. I though it had lean seized but it turned over so I richened the High jet up a little more. Again I tried taking it from Mid throttle to WOT aand it did the same thing. This time I noticed the gas was down in the bottom of the tank so I left and came back about 45 minutes later. I filled it up with gas and I haven't been able to get it to start since then. I've tried the following yesterday and let it sit for 24 hours with the spark plug removed and it still won't turn over. I'm getting a good spark and fuel on the spark plug. I have been trying to start it with the air filter off for good air flow.
So far in the past two days I've tried the following with no luck:
I'm beginning to think I fried my motor..
My motor is the stock HY 26cc with the DDM Modified 27.2 Zenoah cylinder head and a stuffed crank / longer throw piston kit. Walbro 813 carb plus Snappy fuel line kit.
Regards,
Loud72
- Stock Carb
Stock Fuel Lines
New NGL spark splugs
Cleaning screen of 813 carb
tightening cylinder head bolts (2)
Tightening carb outlet bolts
Adjusting coil gap with business card
tightening carb bolts
turning upside down and starting 15-20 times to clear motor of gas
Can't hold thumb over spark pug hole when starting suggesting good compression?
Get a good spark
Regards,
Loud72
