edl
What's the difference between CY and HY engines?
yes for parts in the future, I see more info on the CY but not much on the HY just curious why-thanks
+1@edl
- There is little to no information on the HY engine.
- At best you'll read that the 30cc is a knock off of the CY 30cc or it's similar to it.
- As for the 32cc, totally different story as CY doesn't make a 32cc to the best of my knowledge.
- could it be a knock off or similar to the zenoah G320RC, may be. But can't tell.
Bolt on parts are interchangeable between Zenoah, CY and HY engines:
- clutch plate, shoes and spring
- carbs
- flywheel
- pull start
- exhaust
- spark plug and coil
Perso:
- if it runs fine, run it until it dies.
- then get the Zenoah G320 and be done. Nothing to loose in the long run and money well spent.
Thanks! for the info thats good to know, where can I find a good source on parts for these?
