landmissle
Having some strange issues with the hobbywing ESC. After about five minutes of running reverse doesn't work. When I run on 4S I get about 15 minutes of run time then I hit my LV cut off. Checking my batteries on my charger it indicates about 20% remaining. So all is good!
On 6s I get less than 5 minutes of run time. Car stops running so I change batteries out thinking i have hit my LV cut off. When I check the batteries on my charger it indicates 65% remaining. So both my 4S and 6S batteries are 5000mah 30C. The ESC LV cut off is set to 3.0V. Lipo voltage is set to auto.
I have a CC 1717 motor with stock gearing. Any ideas???
