Deluge and RCdad will chime in... good luck.. its fun to rebuild anyways...rev9fan1 said:k well i did that so now im waiting to see what the issue is
I think that engine is shot. Your best solution is to take your engine completely apart, literally piece by piece... to verify each individual part to see what exactly went wrong. The point of this is to learn what caused it for sure instead of playing the guessing game. First thing that comes to mind is a lean seize. Second would be something fail inside the engine causing all those scratches. You don't have to agree or listen to me but just me trying to helprev9fan1 said:k well i did that so now im waiting to see what the issue is
They sell hex sockets at Lowe's. Just get one that fits the drive on the torque wrench. Carb cleaner will break down the gasket, a bit. Better off replacing it.rev9fan1 said:thats wat rc dad told me i guess its smarter since they are cheaper and they can be just as strong...one day ill get a 4 bolt but until then ill just keep rebuilding it if it fails. Its so easy to diagnose these things when i sit and spend time doing it, i found out the head was leaking cause i sprayed carb cleaner on it. These paper head gaskets though if i spray carb cleaner on it, is it going to make them soft and leak? also how do you torque the head down when its an allen wrench and a torque wrench is a ratchet?
Bingo. That's what it looks like to me.Guantanamo Joe said:If you don't have money to buy a new head, post on here for help and you might find someone who has upgraded their head to the ported kit. I did and would have been happy to send you my old head and piston, but I dropped the piston and it has a nick on it- which will cause exactly what you already have going on.I am no expert, but I have had to rebuild 2 of these already- what kind of air filter are you running and in what kind of conditions? If this is only on the intake side is it possible that some sand or dirt could have gotten in? Are there any metal shavings in the head or crank case?
Looks like dirt got in. If it were a lean seize, the damage would be more significant. It would be like a huge scrape going up the side of the piston.ChuenouXiao said:I think that engine is shot. Your best solution is to take your engine completely apart, literally piece by piece... to verify each individual part to see what exactly went wrong. The point of this is to learn what caused it for sure instead of playing the guessing game. First thing that comes to mind is a lean seize. Second would be something fail inside the engine causing all those scratches. You don't have to agree or listen to me but just me trying to help![]()
OUCH!rev9fan1 said:it is happening on the intake side not the exhaust side AND its below the intake not where the ring is....what makes this happen and what am i suppose to do?
It only takes a second for this to happen if it gets too lean. Sometimes it can happen before you drive it back and shut it down. The piston expands when it gets too hot and then game over. It's the unburnt fuel that helps to keep it cool. When you introduce more air into the engine through a leak you get a lean condition regardless of the carb settings.rev9fan1 said:na im just saying i would much rather have someone that didnt JUST figure out what happen to thier motor help me. Im not angry and it doesn't take going lean for a couple of seconds to do this to a motor.
That might be worth a try. Gaskets are cheap. If it doesn't work your not out anything as the top end is already compromised.Deluge said:Bingo. That's what it looks like to me.Rev, do the scratches go all the way up the cylinder? If the scratches are just in the lower portion of the cylinder, you could get away with just cleaning out the engine and putting fresh gaskets on it. If you could post a pic of the inside of the cylinder, that would help.
That's a good idea. Many upgrade to higher hp engines, so some might have an engine or two to let go.Guantanamo Joe said:If you don't have money to buy a new head, post on here for help and you might find someone who has upgraded their head to the ported kit. I did and would have been happy to send you my old head and piston, but I dropped the piston and it has a nick on it- which will cause exactly what you already have going on.I am no expert, but I have had to rebuild 2 of these already- what kind of air filter are you running and in what kind of conditions? If this is only on the intake side is it possible that some sand or dirt could have gotten in? Are there any metal shavings in the head or crank case?
Just to clarify... Your Royal Purple is the 2 stroke version correct?rev9fan1 said:Its royal purple synthetic 25:1 also the scratches are only below the intake so from the intake up there are no scratches at all. The exhaust side there are no scratches what so ever, but there is what you see in the picture little tiny bit of burnt area, but its not like the intake side. Redcat says they have a life time warranty on their engines, all I have to do is send the old one in and pay for half of a new one....what do you guys think?
