evo3 RR €390
Hi lads here's a rough translation for you
This buggy is now shipping with the new servo-Severn and the tuning discs
The current suspension geometry of the MCD-roader using MCD and other compatible Wheels bring a large scrub radius with it. The current suspension geometry of the MCD-roader using MCD and other compatible Wheels bring a large scrub radius with it. It is disadvantageous, inter alia, the great leverage on almost all components of the steering. It is disadvantageous, inter alia, the great leverage on almost all components of the steering.
Copied to the MCD Onroad there was now the already realized, scrub radius significantly smaller. Copied to the MCD Onroad there was now the already realized, scrub radius significantly smaller. To consider them the wide track on the MCD to off-roaders, extended the axle suspension and the offset of the rims changed accordingly. Them to consider the wide track on the MCD to off-roaders, extended the axle suspension and the offset of the rims changed accordingly. The axle suspension according to the change lies in the interior of the rim and thus reduces the force required for steering movements at a fraction of the previously necessary forces. The axle suspension according to the change lies in the interior of the rim and thus reduces the force required for steering movements at a fraction of the previously necessary forces.
Competition: Competition:
Stabilizer at the front and rear stabilizer at the front and rear
Built LongTravell Kit Built LongTravell Kit
Aluverstrebung lower wishbones at the front and rear Aluverstrebung lower wishbones at the front and rear
2 steel brake discs with brake pads made of sintered metal 2 steel brake discs with brake pads made of sintered metal
6-Kant at all li.-re. 6-Kant at all li.-re. Adjusters Adjusters
Wheels gain for 4 - Kantaufnahme gain Wheels for 4 - Kantaufnahme
Left hand thread wheel axles in the direction of the left Left hand thread wheel axles in the direction of travel
Aluminum stiffening between carrier Spoiler Aluminum Spoiler stiffening between carrier
Spare parts Spare parts package package
Sports: Sports:
1 Stahlbremscheibe 1 Stahlbremscheibe
Standard Standard Shocks Shocks
Hole for suspension of all li. Hole for suspension of all li. re. re. Adjusters Adjusters
Specifications Specifications
Length: 770 mm Length: 770 mm
Width: 460 mm Width: 460 mm
Height: 310 mm Height: 310 mm
Ground clearance: 25-85 mm Ground clearance: 25-85 mm
Weight: about 11.5 kilograms Weight: about 11.5 kilograms
Wheelbase: 510 mm Wheelbase: 510 mm
Gauge: 395 / 395 mm Gauge: 395 / 395 mm
Aluminum chassis, 4 mm aluminum chassis, 4 mm
Trail: 6 / 0 degrees Caster: 6 / 0 degrees
Fall adjustable set case
Adjustable Adjustable Spur Track
4WD 4WD
2 open 2 open front differential front differential
locked center differential locked center differential
Gear ratio: 4:3 - 12.31 Gear ratio: 4:3 - 12.31
(12 different ratios) (12 different ratios)
Tire size: size 65/160 mm (Tarmac), 65/174 mm (Gravel Tire: 65/160 mm (Tarmac), 65/174 mm (Gravel
Only limited number available! Only limited number available!
thats cheap.
for people in the uk/EU we don't have to pay import duty if goods are coming in from another eu country
so just shipping and the cost over the exchange rate
