Excessive compression G320rc
Sivels68
Kuwait Al mangaf
Got a new g320rc broke in shut down took out next day ran sharp turn cut out and never started again. Tried to start today excessive compression . Easy to pull with spark plug out. But no joy with spark plug installed no start
Try the old nitro trick. Loosen the plug about 1/4 of a turn and see if it'll fire up that way. Tighten it back up when it's running, obviously.
Gasket was blown where? I have never heard of an engine blow a gasket and that gives it more compression? all the gasket I have seen blown the engines has less compression because of the air entering in.
exactly
don't make sense does it?
