Exhaust project…
Folly
Amsterdam
I have a Jetpro V2 and a Topscale Twin Pipe (I think pretty rare). Now I want to cut off the expansion part of the Jetpro and have an adapter welded on it so that I can put the double silencers on it.... Please share with me you comments on this 😅 Thanks!
As spents says, chopping the pipe will kill it, they are designed for performance, the chambers are designed for optimum performance, chopping it off then you may as well just remove the jetpro pipe altogether as if anything it will run worse than not having a tuned pipe on at all! If you want to run those twin pipes you have, there is (or was?) a kit you could buy that allows you to do that, but be warned, they add nothing to performance and as already said, if anything the performance of your RC will be worse than just having the stock pipe! ..they are for *bling* only ;)
