Exhaust redirect
rednec
I got the Losi tune pipe,can I cut the tip off and installed copper pipe to redirect the exhaust behind the rear left wheel, its 1/2 inch in diameter
I got the losi tune pipe,can I cut the tip off and install copper pipe to redirect the exhaust behind the rear left wheel,its 1/2 inch in diameter
Should be good if you can secure it properly. You may also look at the silicone exhaust deflectors.
dude don't cut any thing off 1/2" high temp silicon tube cheap and easy, put it to the ground and cut it just above it it can touch the tire all day long it will bounce off before getting cought in tire
