Exhaust?
If it's the stock pipe the bolts that hold it on tend to come loose, Before I changed pipes I had to tighten the right bolt every tank.
You can lock tight a LITTLE red, you can drill holes through the bolt heads and stick something through them. Chevy did one like that. I think DDM? has some bolts with 2 nuts or something that keep them from backing out but maybe not?
Hopefully whoever is running that it is only temperary they don't hold up very well once they get hot it tends to bend. if you want a rear exit pipe for the rampage jetpro is making some i just got one and modified it to fit my prototype xt and it turned out nice and the engine screams with it.
