Silent_Chaos
Hey sup,
I was driving the XB, and the rear CVD Axle fell again from the Diff Cup. This is only happening to the rear. The fronts are ok.
Note that I use the AfterMarket FLM hardened cups and and axles.
You can see from the pics that the pin is not right in the center and has an offset of around 3/4 of the cup length.
So i tried putting the bearings from the inside of the bearing holders just to gain a bit more length(basically reversed the bearing)
I was wondering of someone has tried getting aftermarket diff cups that are longer than the stock. I only need like 0.5-0.7 cm longer so that the pin has more distance to travel without falling off. (Diameter of pin is 4mm)
Any advice would be appreciated. Ofcourse I can either to this, or get 0.5cm lengthier axles, but finding longer cups is a much easier solution.
Any other brands that have lengthier cups and have a pin diameter distance of >4mm ?
Thanks
Thanks
