extra drive pinion bearing
max 1
I was replacing bracke sqaure ,and notist a spot fore another baring in the outer center diff caryer ,so i went threw my bearings i had off of my mutilater , and 1 of the layshaft bearings fit i the opisit side of the caiyer, no more shaft wabell .so now i have 2 bearings to suport the shaft ,
Clubin said:
I noticed that there was a space, that is a good thing to know. Good find man. You wouldn't happen to have the measurments of the bearing would you?
i don/t have my mic with me ,i/am at work i/ll check wen i get home .center is a 10mill.it fits in the cut out perfect.
max 1 said:
i Don/t Have My Mic With Me ,i/am At Work I/ll Check Wen I Get Home .center Is A 10mill.it Fits In The Cut Out Perfect.
I Think It Is A 10x22x6 I Will Make Sure To Night.
pleas a pic
I don,t have a cam i use my stash fore parts.the bearing go,s behind the brake sqare.wear rhe shaft coms threw the mount ,thaers a cut out fore a bearing 10x19x7.it fits right in thear.sorry no cam yet.
