FG 4wd and Elcon air brakes
kevinl2375
NSW, Australia
Does anyone know if the Elcon air brake system works with the 4wd.
I was also wondering if you can also get it for front and rear.
Or if you need it on all four corners at all.
And last of all.
How do they compare to hydro brakes.
The Elcon air brakes work very well. The don't fit the 4WD models and also do not have them for the rear. They come with their own uprights so the system can bolt on. It gives you a full 360 braking, other brake systems only touch part of the brake disc. Much better than hydro's. I have a Cleon with airbrakes and a FG 4WD with front cable brakes and rear steel layshaft upgrade. The brake systems are also only as good as your setup and servos.
Elcon makes kits for their Cleon as well as FG's, Hormann's and working on one for the HPI Baja/5T.
