FG Baja 4wd Brushless
monsterbaja
Norway
Hey guys, here is some pictures of my Brushless project
picture.php
picture.php
picture.php
picture.php
picture.php
lovely job.
do you mind me correcting something?
a mistake i made ages ago.
your layshaft gear is too heavy,you have the heavy duty widened diff gear on that spur adaptor,too much weight,it will not stay on,you need the narrower lighter gear.
cheers
lovely job.
cheers
Thanks for the tips.But i have one on the way.:)
The motor is a heli obl ..770kv.. 10s.
I am going to run it on 10s(37v)28000rpm.
The Esc is a Titan 85/110 A,12s.it is a little small ,but it will do for now.
lovely job.
cheers
he runs with the original parts fron the FG Baja 4x4. hadde the same prts on my DFG marder and had noe problems with it.
this allu hub and spurgear combo came on the market last spring.
a great hop up that gives you the posibility to switch between 48t, 46t and 44 tothen spurgears without switching the spurgear hub.
stå på Monsterbaja. regner med gutta her er like ville etter å se den gå som vi i Norge er.
a litle intern between me and Mr MOnsterbaja. we have had ouer discutions on a Norwegian RC forum.
link www.radiostyrt.no.
What items are required for this conversion? Any model or part numbers you can share that are needed and/or used?
Hey there WoodiE.It is kind of hard,because i have made all the mounts my self.but when i am finish,i will post all the measurement on the mounts:)
