fg baja buggy
I worked at Spire Dunedin Hospital in Bath Rd just over 12mth ago on the theatre upgrades.
That's my neck of the woods, I live about 10 miles away from there. If you worked there you must of seen a place called prospect park, will be going there at some point this weekend, weather permitting
Is that on the LH side as you drive from the M4? Looked like a decent bash site :cool2:
Did you go for a bash today or were you a good boy & went to work!!
Well just had a bash, on wet grass. Damn the throttle is twitchy, found it hard to keep in a straight lines, pretty good at 180's pmsl. Just waiting for the batteries to charge again. Very quick, love the power slides!
What tyres are you running? The standard spikes should give good grip in soft wet conditions if they have plenty of life left in em.
Get some pics posted of your dirty marder!! There are too many pics of clean cars on here (inc mine :o)
How can I upload pictures???? I love this car, was having a bash with it and after a while the sound went from a growling to real snappy barking sound, i think the previous owner was putting to much oil in, there was a little fuel left in the tank, before i filled it up 25:1, seemed more responsive. Had a go on tarmac, tried to pop wheelies but just got the tyres smoking up! All good fun
best bet for pictures is open a photo bucket account then upload pics there (Photobucket explains how to do all that) and then add the img code here then the pic apears here..
it sort of looks like this
except I added a bit so you can see link and not picture
if taken out it should look like this
this is how they should all look DIRTY!!!!!!!:lol::lol::lol::lol::lol:
Fg mader
Hi people I have just had to replace my steering servos today after replacing them I turned car on to make sure they were ok and they worked fine turned the car off for five mins when I turned it back on there was no power at all the battery is fully charged so I thought it mite be a dodgy power switch so I plugged batt straight to the receiver still no power but it was working before I turned it off can anybody help me :)
Is it both the throttle / brake AND the steering servos that have no power, or just one?
I'd definitely check the leads.
How are the battery connections?
Is the battery hot?
Other than that, you might have fried the Receiver (Rx).
Al.
Hi again I have just found out that I have fried the reciever can I put a new reciever on without changing the transmitter thanks dwain
Depends if you're use 2.4ghz or the crystal radio gear mate, if using the crystal type as long as you use the same crystals then yeah but the. 2.4 ghz is slightly different, if your controller accepts more that one receiver the all you need to do is bind the new receiver ;)
;) If it ain't broke, bash it till it is ;)
