Fg baja problem
dhirsty
london essex
Hi all on the air line and petral line which 1
Has the fillter on it coz I've got a small black air
Line wiv fitter on and it goes to the top of the
Carb and a big yellow 1 that goes to the bottom 1 ave
I got them mixed up having problem runnin and
Smells like plastic burning???
top of carb is the return pipe, this just returns unused fuel to the tank, the bottom one is the fuel line this is longer than the return pipe & lays in the bottom of the tank with a filter on it, check to see witch way round yours is
F
Also wen I roll the buggy back n fourth the clutch bell rings is this
Normal coz got to pull the engine out again drives
Me mad.... It makes me wont to give it up and burn the bloody thing
Yeah Its normall mate, why you got to take engine out ?
Don't give up mate, these petrol motors are the best rc cars out there IMO
Brad.
Oh. coz it revs and the clutch ant working not moving mate... It's got a red spring 8000rpm and 28/36 gears it well quick but keeps on having problems
1 thing afther other..... Wot gear ratio r u runnin matey
That sounds a bit of a low ratio for an off roader mate, will probably be putting strain on the clutch and burning it out, I would put it back to the sock gears for now.
Brad.
Yeah true but mine is fast too.... I've just order a new standard clutch and spring hope it will b better lol......
