Fg Baja wb535 engine mount
CALIC
Slough, UK
Hi all, i had recently bought my first 4wd fg and thought il buy the essentials and so i started with the alloy engine mount (big and small). Yesterday i got the mount delivered so i started replacing them but the damn layshaft gears will simply not site properly with the diff. I had tried every trick in the book but its just not happening. Every time i tighten the engine screws, the gears will just not turn. Am beginning to wonder if the mounts are different? As when i put back the original plastic (large) its fine? Putting both engine mounts side by side there is no difference in hight.
Any one had this problem before? Any help will be much appreciated !
