Fg baja
dhirsty
london essex
The rear wheel turns and the other don't
Then wen I turn the other 1 it is stuck
Wots going on??? It has mud all over
It is that y?? Pls help lol
Give it a good clean and make sure there is no grass wrapped around the hubs & shafts that could be causing the problem. If that doest sort it, drop the drive shaft out & make sure the wheel turns freely and its not seized bearings. If all is ok there it would suggest the diff is the problem.
Yeah the left 1 turns and the right 1 don't then the right
1 don't turn at all
If the right wheel doesn't turn at all when you try turning the right wheel you need to look at it before you take it out again!
+1 on that Andy....................if you don't look at it
take a strong piece of string with you,so that you can attatch it to the
front bumper:lol::lol::lol:at least you will be able to pull it along:D:D:D
K....
K....
Good advice Keith :lol::lol::lol::lol:
